Our Blog
HomeBlogWhat You Need to Know About an Emergency Tooth Extraction
woman suffering from emergency tooth pain
Knowing when and where to get an emergency tooth extraction can save you from continuous pain, distress, and potential complications. If you find yourself in a situation where you are experiencing dental pain and discomfort, having information about when, where, and why an emergency tooth extraction takes place is important for you to make informed decisions and know who to contact during a dental emergency.
Understanding Emergency Tooth Extraction
An emergency tooth extraction is a straightforward dental procedure where your dentist will remove a tooth from its socket. First, your dentist will assess your situation, evaluate if the tooth can be saved with a different course of treatment, and only if deemed necessary due to severe damage, a threatening infection, or extreme tooth trauma, will remove the tooth. Extractions will often immediately alleviate the pain you’re experiencing. An emergency tooth extraction is different from a planned extraction and is carried out when the situation needs to be addressed immediately.
When Should You Consider an Emergency Tooth Extraction?
Understanding when you should get an emergency tooth extraction is critical to your dental and overall health, as well as your comfort. If you are experiencing one or many of the following symptoms, you should consider seeking an emergency extraction:
  1. Severe Pain: Persistent and intense dental pain can indicate a significant dental issue that may require extraction.
  2. Infection: If you are experiencing swelling, fever, a bad taste in your mouth, or pus around the affected tooth, these are all indicators of a potential infection, and it should be addressed and treated immediately.
  3. Tooth Decay: In the case of severe tooth decay where the tooth will not be able to be restored by other treatments, extracting the tooth may be the best course of action.
  4. Trauma: If you have a cracked or broken tooth that is causing extreme pain, an emergency dental extraction may be necessary.
Can You Receive Emergency Dental Treatment in the ER?
Although an emergency tooth extraction can be classified as a medical emergency, ERs are typically not equipped for dental procedures like tooth extractions as they do not have onsite dentists or the appropriate tools. In most cases, the emergency room staff would provide you with antibiotics for the dental infection, but tell you that it is still necessary for you to visit a trusted dental clinic that provides emergency dental care.
Where to Go for a Dental Emergency?
For any dental emergency, including the potential need for an emergency tooth extraction, you should research local dental clinics in your area that provide emergency services. However, dental emergencies don’t always happen within the regular hours that many dental clinics are open. Be sure to find a clinic that provides 24/7 emergency dental services in your area so that you can be treated urgently. After finding a clinic that provides round-the-clock care, make sure to call the number provided so that you can be cared for immediately, regardless of the time.
Emergency Tooth Extraction: What to Expect
Now that you have found a 24/7 emergency clinic, it is natural to feel nervous about the following procedure. The good news is that an emergency tooth extraction is a straightforward procedure, and you can typically expect:
  1. Assessment: The dentist will evaluate the situation, take your medical history, and conduct X-rays to determine the best course of action.
  2. Anesthesia: If an emergency extraction is the best course of action, a local anesthetic will be applied to the area to numb the site and provide you with comfort throughout the procedure.
  3. Extraction: The dentist will carefully remove the affected tooth using specialized dental forceps to loosen and remove the tooth while being careful to preserve as much of the surrounding bone and gum tissue as possible.
  4. Post-operative aftercare: After the extraction, you will receive detailed instructions on how to care for the extraction site to aid in the healing process and prevent any complications such as infection or dry socket. You may be prescribed pain medication to help with any pain or discomfort while the site is healing. It is important that you follow your dentist’s aftercare instructions to ensure a quick and smooth recovery.
Visit Our Emergency Dentist at 32Ology Dental Studio for Emergency Dental Services
If you find yourself in need of urgent dental care and are experiencing intense oral pain, severe tooth damage, or possible infection, our team at 32ology provides comprehensive 24/7 emergency dental services to address your needs swiftly and efficiently. We know that dental emergencies hit when you least expect it, so we’re available 24/7 by phone.
Don’t let dental pain disrupt your life. Visit us at 32ology Dental Studio for efficient and compassionate care.
32ology Dental Studio – 24/7 Emergency Dental Assistance, Los Angeles, CA
18740 Ventura Blvd., Ste 108 Tarzana CA 91356
(818) 776-1236
SCHEDULE AN APPOINTMENT
